Someone needs to teach you how to take a screen shotSo... Doing some digging through data logs.
And I believe holley DOES kick the limiter when it senses slip.
Limiter setting.View attachment 523341
You can see in this last datalog, at 6300, the rpm (red line) kind of plateaus. Then at 6400 it kicks the limiter (blue spike)
Yes im in the process of letting off, but it's clearly still accelerating lol.
On my trans log, you can see it shifts, but the input shaft speed (green line) keeps going up. Until it kicked that limiter and I let off.View attachment 523343
Same type of log with the original trans a year earlier.View attachment 523344
Input shaft speed drops as soon as the shift happens, as it should.
During that run, no limiter happened.
So, HOPEFULLY, it won't happen anymore with this new transmission.
You might find some help on the Holley forums, or just googling, on the actual algorithm for over-rev protection. Maybe you expect it to do nothing until the rev number is 6800.00, but it may start lower based on "RPM dot" (1st derivative of RPM). Especially if you're in neutral (or break your diveline or something bad), you could overshoot in the time it takes the adjustments to take effect. Some software has like a desired max and a hard limit.
What does it do? Just cut all spark?
I suspect it's just an artifact of how it draws the graph - it's always connecting data points with straight lines. You'd need infinite points to get truly vertical lines there.However, when it hits the rev limiter, its either on or off, 1 or 0, so it doesn't make any sense you have two diagonal lines, that is not normal. What happens in the data log when you hit it, each time you hit it, it has two vertical lines, one for when you hit it, and one for when it turns off. Because its normally 0, then you hit it, it goes to 1 for on, then back to zero. Its a single digital data point, 1 or 0, so a diagonal line doesn't make sense.
Yeah I went and looked at one of mine, it does the same thing, but my scaling uses the entire height of the graph screen so it appears vertical, when you make the line 1/3 of the height, then the slight angle is obvious.I suspect it's just an artifact of how it draws the graph - it's always connecting data points with straight lines. You'd need infinite points to get truly vertical lines there.
When your in burnout mode, at your 6500 limit 1, does it reach 6500?
)I'm using the same one you are. Just set at 6800 instead of 6500. So if you can get almost to 6500, then I should be able to get to 6800 lol.Yeah I went and looked at one of mine, it does the same thing, but my scaling uses the entire height of the graph screen so it appears vertical, when you make the line 1/3 of the height, then the slight angle is obvious.
It is still only zero or 1, nothing in between in the data, goes from 0 directly to 1, however, one data point over is .020 second later in that resolution I recorded, so that makes the line at a very slight angle that appears vertical with the full height.
I have hit it if I have the throttle too high yes, usually I am just below it as I don't let it sit on the chip. (we still say hit the chip even though we don't uses the little chips/capsules any more.)
If you want to send me your log and your tune file I can overlay and look at it for you. It might just be a matter of switching what rev limit type you use.
I seriously think it wasn't happy with what the trans was doing, (hey, I shifted, but the shaft speed is still climbing!), and trip the limit as a safety.
I'm pretty positive it's not going to do it with this trans.
And, around like July or something last year, I believe I sent you that log and my tune lol.
Because of the limiter. May have been later than that. When I get a chance I could again. But I don't believe it's in my limit settings at all.
I know I was able to get near the limit with the original trans. I had it set to 7100 with that engine, and I know for a fact it was still smooth at 6900 once, because I had the whole "69!!" Moment lol.
Didn’t my truck have this issue?I don't data log the burnout, I did for a few runs years ago but always had to zoom in to the run so I just eliminated it, I may be hitting that one it at 6300 I don't know.
I can tell you this, I have had to adjust the shift point lower so I don't hit it. And I know of a lot of people, including myself who have had to move the rev limit higher to have a clean run off the rev limiter. If its consistently hitting it 400 RPM low, you can raise it up.
For example, my shift points are 600 - 700 RPM lower than my rev limiter, because if they aren't, I hit it when I spray it, and it shifts firm too, no slipping. SO a shift point of around 6800 for 2nd gear and my actual RPM hits ~7440. Without the spray I can get away with a little higher as the RPM is climbing slower, but its still a big gap from shift point to rev limit, because in that short amount of time the engine climbs 600 RPM or more.
I have a dominator ECU, not a Terminator X Max, so they may not be exactly the same, but I have used Terminator X with a lot of success too, if you dont need internal data logging or high current injectors don't spend the money.
