LSX454 swapped 95 BASS burb.
Little lower, little cooler, bigger sounds.
First brake assisted burnout worked amazing.
Didn't even hesitate.
Stop, hold button, smashed it, spun like hell. :thumb:
So it likes the new converter/trans?
I'm going to look at that decay time.
I know I changed the decay time somewhere along the line trying to get it to idle down sooner after start up.
My have changed the wrong decay time.
What's weird is when I'm off throttle, rolling, it's all good.
When I get to the last part, right at giving it a tad more brake to actually stop. The engine will real quick like dip to like 400rpm, 10-11 AFR, and
Then it'll either catch its self, or it won't.
I can let off the throttle completely and roll for half a block lightly on the brake. Idles the whole time, fine.
The last 5' when I'm in the brake a touch more, it does it.
Almost every time.
Do you have that gray brake wire hooked up to the brake switch? Not saying thats it just curious. Although if you are already pressing the brake and just pressing it harder does it, then that's likely not related. Sounds load related.
It might be something as simple as adding 50 RPM to the target idle and reteaching the IAC again.
I would chime in with my $.02 but instead you should listen to @folkenheath .
When I had my truck dyno tuned they would tune at every 100RPM increment through the whole throttle range.
Are you drive by wire or throttle cable? There is an important step you have to do with a DBW setup that will make the IAC not work properly if you skip it.
This is mine, you can see the throttle pedal map starts at 11%, not 0%. That's just a little too "closed" to idle at my target RPM with the engine fully warmed up. The IAC can only open it a certain percent past the lowest point of your throttle pedal map. If you don't change that your throttle blade will barely be open on decel.
A DBW does not use an IAC valve. They delete the IAC and just open the throttle open slightly and control it with the electronic throttle.
Correct, that is what I was trying to say. If you don't set the pedal curve to start at just below the throttle position it idles at, it won't have enough range to control idle when it's cold. I had this problem when I first converted to DBW and had to figure it out. When it was cold it would idle at 650 even though I had it set to 850 because the IAC function of the throttle body was already at 100%.
Yes it LOVES the new converter and trans :thumb:
Gray brake wire is hooked up. That's how it shuts lockup off and such.
And I've had the idle set as high as 1050 before with the old engine. Still did it.
Did you try it with and without the idle spark enabled?
If you are sitting there and you hit the brakes really hard, what does the IAC do on the screen?
I shut the idle spark off last summer and it flat quit idling. So I turned it back on and adjusted the values. It did help, and died less than before.
I'm going to try raising that timing down low. And if it's better, I'll try shutting the idle spark off again.
I'll try looking at the iac, but if I'm just idling in gear and push the brakes super hard it'll noticably drag the engine down for a bit.
I'm going to head to the shop in a few minutes, and try to get my door panels on.
Right now I can't put the windows up.
If I get the door panels on, I'll drive it to work, and do a couple data logs in the morning.
This corner I thought was all 18.
Not sure if I was confusing an older map or what.
But I moved it all up to 22 anyway. Since it was the lowest on there, and happens to be the area it tries dieing.IMG_20260715_183137184_HDR.jpg
That doesn't sound right, seems like a clue something is wrong that it doesn't like to idle on it's own. The idle spark is supposed to help it idle smoother, it should idle fine without it. When you make changes to the idle, look at the MAP, if it makes more vacuum (lower kPA) or increases RPM, then the engine liked it. If not, go the other way with what you did. You may need to move the throttle blades and reteach the TPS during this procedure. Make sure the learn table isn't dumping a bunch of fuel at idle because of overlap, try more or less timing and see what it likes, and also more or less fuel, you can do this live, while it's running. If it won't idle on its own without idle spark in neutral, you may need to open the throttle blades, recalibrate the TPS, then test. It may take a few iterations to get where you want.
I went back and found the logs from that. It didn't quit running or idling..
I remember, what it was is I couldn't even put it in gear with idle spark off. With it on I can drive it. With it off it dies every time I put it in gear.
Forgot this step.
So figured I'd better do it before I entirely forget.IMG_20260716_160055685_MP.jpgIMG_20260716_155935453_HDR.jpgIMG_20260716_160108678_HDR.jpg
Cavity wax with these long 360 spray wands to coat the inside of all my new metal work.
Tomorrow I'll put the snake cam in there to see if I missed anything, and re coat most of it anyway.
Then body plugs and I'm free to drive it whenever..
Not if I don't drive it in it :waytogo:
This gets put away when they put salt down, and doesn't leave the shop drive until at least 4 heavy rains after the last salting of spring.
The body drain passages are technically still open. And are designed to be. The body plugs just keep the worst out and give access to put stuff like this in I guess.
Not sure if the factory does anything like it.?
But they had all the holes and plugs for some reaon:dunno:
Primer dipping.....? Dunno.
