LSX454 swapped 95 BASS burb.
Little lower, little cooler, bigger sounds.
Good burnout.
Did the video just start or did you trim it to that? That sound is so early it could just be the end of the cackle or where the sound isn't fully in yet.
That's the whole vid.
No trimming
She was supposed to start it recording. Wait a few seconds, give me a thumbs up, and keep the truck in center frame the whole way. :haha:
Things to do this winter season....
A. Pull trans and get it back to the builder.
B. Swap the heavier front springs in and set final front height.
C. (If I can get to it) Remove rear bump stops, and see if I can adjust the rear height down an inch.
Other things I have to do that are non burb related, but have to be worked in there, and are sort of more important than B or C.
1. Fix a bunch of chit on the wife's monza with her.
Floor, weather strips, and all suspension bushings.
2. Rebuild my buddies A904 transmission in his Cordoba. It Has absolutely NO reverse, but seems to have all other gears (gotta check 3rd yet)
3. Fix the oil leak in the wife's Daily if doable semi quickly.
Random m question...
@folkenheath
Maybe you know off the top of your head.
Is there a way with the terminator, to program an input that will raise my idle setpoint to a preset..?
Like 1200-1300 or something?
I was thinking a toggle switch to AC kickup, or something like that. :dunno:
When I'm idling, doing stereo demos, the bass alternator pulls the engine enough to make idle swing rapidly, and sometimes will kill it altogether.
If I don't turn it down during a real bassy song and it's in gear it WILL kill it. But thats not a big deal because I usually turn it down at intersections anyway out of courtesy.
I'm on vacation starting the 28th of this month.
So planning on just biting the bullet and yanking the trans like the 30th. Gives me tim to drive it up to the builder, and drop it off.
And possibly, hell have it done looking it over in time to get it again before the end of the year.
