bp71k5
3/4 ton status
That’s odd. I must use mine or else the cord won’t budge.![]()
The new ones have something called “smartstart” which I assume replaced the decompression button?
Y'all have pine beetles down South? I thought it was a western state or high country issue.I don’t know if it was mentioned earlier in this thread but it looks like you may have pine beetles. If so they will keep on killing the pine trees until you cut down all of the ones that are infested.
really should have saw on the ground braced and then even if you forget its not too big a deal. Seriously though probably shouldn’t ever drop start a saw, dont one hand a saw. Keep the wood against the saw(the teeth on the motor) Cut so if it does kick its not coming across your body and your hand is in a position the brake will work. If you want to lock the brake do it by rolling your wrist not taking your hand off the bar and pushing it with your palm. And have someone there with you. Even if you just have your wife or kid there to call help. Saws can get away from you in a hurry and it can get bad quick. My dad tried to shave with a chainsaw once. Coulda been alot worse, he was lucky.Our smaller sthils at work dont have the decompression button, the bigger ones do. Pushing the decompression button makes it easier to drop start a saw. You shouldn’t do this and I never doreally should have saw on the ground braced and then even if you forget its not too big a deal. Seriously though probably shouldn’t ever drop start a saw, dont one hand a saw. Keep the wood against the saw(the teeth on the motor) Cut so if it does kick its not coming across your body and your hand is in a position the brake will work. If you want to lock the brake do it by rolling your wrist not taking your hand off the bar and pushing it with your palm. And have someone there with you. Even if you just have your wife or kid there to call help. Saws can get away from you in a hurry and it can get bad quick. My dad tried to shave with a chainsaw once. Coulda been alot worse, he was lucky.
In the air no way around drop starting it and they figure it will just rattle off the bucket so its OK. Im not a tree trimmer by any means, we just hack and destroy stuff outa our way
We call the pros if it’s something big.We run ours a fair amount so they start easy. The old one cough on choke and the next pull they start on idle. But still best not to drop start em. I’d get time off if they caught me doing it on the ground. So I never doIn the air no way around drop starting it and they figure it will just rattle off the bucket so its OK. Im not a tree trimmer by any means, we just hack and destroy stuff outa our way
Any of you guys use the premixed gas? Its expensive but lasts awhile and you dont have to monkey with a dump container or what to do with the last splash in the can or trying to get your mix right with leftovers. Thought it was a racket till I started using it.
its non ethanol high octane. Some fuel stations its hard to find pure gas. Stores well especially unopened. And convenient that you dont have to run your can out or find a place to hide it or use a dump can and cycle between 2 cans. Saws do seem to like it better. Ive let it sit in saws and weedeaters longer than it should im sure and haven’t had an issue yet.
I imagine a tiller blower or old school mower might eat a ton of it. We buy it by the pail and drum at work. For home though the small cans last me forever in my saw and weed eater for as much as I use em.
actually tying into the Milwaukee thread for my home use Id probably go that route since I dont use it a ton. Some guys have the Milwaukee pole saws and chainsaws at work as a trial and for regular use Im not a fan but for the house they would work. Actually im pretty impressed with my Milwaukee blower. Its not got the power of gas but its decent.
