M1008 Cucv Ls Swap Cadolet Build, long range Blazer Bash 2026 prep
Converting my M1008 from 6.2 Diesel to LQ9 power
I think I need my steering box rebuilt , the steering just really lose its like driving a boat, is there anything i can do to mine on the truck to help tighten it up or is it all internal stuff? if I do rebuild it, is redhead or blue top better or are they the same just depends on who you get rebuilding your box? if it hard to rebuild at home? help!
You can adjust the backlash in it and tighten it up. There should be videos on the YouTube. I think both red and blue are equally good. I heard a guy left one of them to start the other. I was gonna put one on my super duty. Ended up with Napa reman on both it and my K5. For what I do they seem fine.
@4X4HIGH rebuilt it around 2010, it does not have a ton of milage on it, just feels loose. ill look up a video.
You adjust the gear mesh I believe, and I wonder if it's just broken in and needs a tiny bit of tightening up. I've done mostly high mileage wore out boxes and got them to drive better by adjusting before replacing.
You have cross over? If not double check the pitman is tight on sector shaft.
It is best to remove box and adjust on bench using an inch pound non clicking torque wrech to check.
I have cross over, I have a inch pound but ( non click? you mean when it reaches the desired inch lb?)
Bender type or dial type, only way to read rotational torque, for us. I am sure an engineer has built a machine to do it.
Toe-in set after the new springs and tie rod? Did the new springs change the caster? Air pressure in tires checked?
It's the same before the spring swap, I do need to do an alignment at some point. I don't think the springs changed the caster. But I'm not 100% sure. I'll call you later tonight if yo u are free.
