100%Our internet friends are bad influences.
No she would yell lolBut he could tell his wife he saved money, he was expecting it to be a $500 upgrade, at under $100 his friend saved him $400! Isn't that what they would say?![]()
Don’t forget to get all the old silicone out of your bolt holes. I like to use compressed air but make sure you have safetyglasses on!I got the Spartan Locker installed today. I still nedd to make it it's working correctly and then I'll button it up.
Good call, I'll clean em out good.Don’t forget to get all the old silicone out of your bolt holes. I like to use compressed air but make sure you have safetyglasses on!
Is it just the rubber part or the sleeve tooAnyone ever have to trim leaf spring bushings to make them fit between the rear spring shackles? I have to do this to make the bushings fit. I got. The old springs out but the new springs and bushings are too wide for the spring shackles. I got the spring eye adjustment plate installed on the new springs and I was going to installed them and. We found that the bushings are too wide.
Well you can shave a little to make fit snug.Rear spring shackle hanger, sorry for the confusion, bushing and sleeve are same length. Just don't fit between shackles.
^^^ this, then tighten back up.Did loosening the upper shackle bolt help?
Me either!I didn't know they had a factory spicer 35 spline option.
I believe they are the stock outers for a dana 70I didn't know they had a factory spicer 35 spline option.
