Fred_M1010
My build is at a stand-still for the moment, so I thought I might as well start a build-thread and post some pics, while I wait for the inspiration to return
All feedback are welcome both good and bad!
(I know spelling and grammar sucks though, so you don't have to point that out
My first build was a 2500 silverado, but that was both expensive and
not very reliable offroad (6" lift and 37" tires).
So this time I started with a -84 CUCV K30, with the plan to make it as cheap as possible.
This is how it looked before I messed it up.
It's an M1010 ambulance, that served in Desertstorm (from what I heard), but later got imported to Sweden, where it served as an ambulance in a swedish mine before I bought it.
EDIT: Sneak preview after modifications:
I started working on it this winter.
First I installed 56" springs up front.
I lenghtened the framerails a bit for the front bolt to fit after I relocated the front spring-hangers.
I really liked the CUCV tow-hooks, so I welded a piece of angle iron to them for two of the spring-hanger holes.
I left the rear shackle mounts in their original position.
I measured along the arch on the springs to see how long they could be at maximum.
Then I used that measurement to determine how long shackles I needed.
It ended up 8.25" c/c (with reinforcement)
I let the reinforcement follow the profile of the frame with a 1/4" space in between,
when the shackle is in it's rearmost position.
That makes it a little stronger without making the shackle unnecessary long
This is how the shackle-angle looked like at ride-height
If you think the leafpacks looks funny, it's because they DO look funny.
I got a pair of main-leafs for free, so in the hillbilly-spirit of this build I mixed and matched up the leafpacks with springs from both 54" and 64" springs
Next step was transforming it into a regular pickup truck
(The CUCV-crowd will probably kill me for this
First I removed all the rivets.
Then I cut out the sheetmetal from an old K10, and measured completely wrong doing so
To top it of I welded it way too fast, causing it to warp
But who cares anyway
To be continued...
)My first build was a 2500 silverado, but that was both expensive and
To be continued...
. Hopefully this will give me some motivation to finish my cucv project once I get it out of storage this weekend. Also welcome to CK5, saw you were a new member, hope you enjoy the site, there is definitely a ton of information here.
