10/29/10 - Today I took off the front plastic to measure for a transmission cooler. Then I started calculating cut lines for the back.
11/3/10 - I removed the driver's side front locking hub and replaced a broken allen bolt. I removed the factory transfer case adapter and cleaned the area around the input shaft. I ordered a transmission cooler and transfer case input shaft seal.
11/4/10 - I bought the transmission jack below for $80 from Harbor Freight. I lifts 24" and should be both high enough and low enough for my needs.
11/5/10 - I cut out the old transmission cooler lines then flushed the transmission cooler. I cut up 1 1/2" X 1/4" stock into eight 6" lengths for my transfer case drop. Currently there were four 1" tube spacers for the drop. The spacers do not effectively distribute the weight on the frame resulting in cracks so they had to go. Finally I assembled my transmission jack.
11/11/10 - The guy rebuilding my transmission finally got back from hunting out west. He tore the tranny apart on Tuesday. I am going with a rebuild kit rated for applications up to 400 horsepower and a B&M shift kit.
My old transfer case drop spacers are in the center of the picture below while the new ones are on the edges. The new ones will distribute the forces exerted on the cross member over a much larger area of the frame.
I ordered a new torque converter and bought 5/16" brake lines to make new cooler lines for the transmission.
11/14/10 - I installed my transmission cooler. It was too big to fit against the condenser so I had to build brackets for it.
I cleaned my transfer case then installed a new input shaft seal. Finally I redid my fan shroud mounts so it would mount securely.
11/16/10 - I pick up my tranny tomorrow at noon. My torque converter should be in at 2:00. I have everything cleaned and ready to go. With no surprise changes to my schedule, it should be on the road on Friday.
11/17/10 - The torque converter was not in today. The counter guy at NAPA swore he ordered it but the company said they didn't have an order for a TH350 torque converter and it would take 2 weeks to get one. I can't wait for 2 more weeks so I ordered a B&M torque converter that should be in on Friday. NAPA gave me a deal but it still will cost more.
11/19/10 - No torque converter today.
11/21/10 - I test fitted the transmission today without the torque converter to see how my new transmission jack worked. I was amazed at the improvement and control compared to a floor jack. Well worth $80. As long as I had the transmission in place, I made the output line to the radiator then connected the transmission cooler adding an inline transmission filter to the return line after the cooler. I still have to make a return line from the filter to the transmission fitting. Finally I changed my vacuum lines so the one going to the transmission was independent of other lines. I put a T in the vacuum line for my evaporation canister then connected the line for my climate controls to it.
11/22/10 - I picked up the torque converter at 3:30 today and finished installing the transmission.
11/23/10 - Not much progress tonight. I attached one of the adapters to the transfer case then put sealant on the other one and positioned in on the transmission. The transfer case with its irregular shape would not effectively sit on the transmission jack so I could line it up with the transmission. After multiple tries I gave up and ended up building a cradle for it. Now in addition to installing the transfer case tomorrow I have to scrape off all the sealant again.
11/24/10 - I got the transfer case and cross member installed. All the jacks are removed and it is finally free standing again. If I would have had a friend help me yesterday, I could have finished it today. Now it will have to wait until Friday or Saturday.
11/26/10 - Tonight I got in 4 hours of final installation of all the little stuff. I also cleaned up wiring on the under side of the vehicle. Tomorrow I install the drive shafts, add fluid and start it up.
Jiminy has been down for 6 weeks. When something breaks I like to fix it right away so this has been annoying.
11/27/10 - All done. Tomorrow I will put some miles on it.
11/28/10 - I put 50 miles on Jiminy going to Wausau for kerosene then another 25 miles getting a Christmas tree. We always need to find a Christmas tree with a bird's nest so it took most of the afternoon.
Now I have to clean up the mess.
