Got everything disconnected/removed from the engine, unfortunately in doing so noticed the positive battery cable sheathing is burned down by the starter. It was an Exide "universal" battery cable but did not have the "proper" 90* bend at the solenoid like I'm used to with the OEM cable. I bent it, since the solenoid + terminal is right up by the block.
The cable Delco sells now for an '85 K5 (4SD65X) would be hard pressed to be more generic:
Since they can't get it right, I'm thinking build my own.
Going to stick with a side terminal design, and I *think* 4AWG is stock, which was enough, but I know technically it's undersized for the draw, so going up in size a bit wouldn't kill me.
Found these guys, they have much of the components...side post terminals https://ceautoelectricsupply.com/product/side-post-battery-terminals/
and 90* eyelets... https://ceautoelectricsupply.com/product/90-degree-mega-eyelets/
and cable... https://ceautoelectricsupply.com/product/power-cable-translucent-red-jacket/
Anyone have experience with other suppliers that carry this sort of stuff that they recommend over what I've found? Will solder hold up, or is a crimp (or crimp+solder) the best choice?
