Randy92782
1 ton status
is that a coleman sticker on thhat fender?buefchris said:I just butt welded everything, they came out a little warpy,so youmight wanna frame'um. And unless you make a access hole, you should weld the lock set-up inside. I used that lock rod to open the doors.[just pull up that silver ball.]View attachment 55222
just gettin my pont across
