The Pumpkinator
There are many strategic attacks out there for the removal of Dana 60 upper kingpins, but which method is the quickest and worry free? Ive poked here and there around the web for different ideas and procedures, here are some that I found;
Welding 2x2" square tube to the kingpin and wrenching it off with a large pipe wrench and a 8' cheater bar.
Making or purchasing a large piece of 7/8" hex stock, heating the king pin, and wrenching it off with an 8' cheater bar.
Attempting to quench the kingpin with either ice or cold water.
Drilling out the kingpin entirely.
Grinding a thin, deep groove around the base of the kingpin to alleviate the pressure between the two mating surfaces.
I'm sure there are a couple more tricks out there, but what do you do when your rebuilding your 1 ton gem on a bench without a truck sitting on top of it? Or what happens when the top kingpin hex fitting twists apart, or your tools break? What about the fear of galling the threads by overheating the inner knuckle casting and placing tremendous amounts of torque on that kingpin? Even more scary, what happens when that pipe wrench slips and hurdles toward your truck's pristine sheet metal or even yourself?
Here's my painless/hassle-free quick procedure that worked surprisingly well for me...
I was even using new craftsman drill bits so they were sharp for starters. The first pilot holes with the 1/4" were somewhat painless but going up in sizes proved increasingly difficult even with the 1/4 pilot there. After breaking the first kingpin loose and going over to the other side, I even gave up and decided to just try it with the 1/4 hole.
