My first post to your rebuild manny - wow!! Good work man!
Although I'm not much into your engine (I'm a diesel guy mostly), the D60 write up is next to nothing. Should mentioned side by side with the D60 bible on pirate.
Keep on the good work!
Just my 2 cents on two things:
Looking at your spindle install and the little grease job you did there
, reminds me of my spindle bearing greasing tool (fabricated years ago by a good friend). This d*mn little bearing is hard to reach and the first that gets dirty from the outside. The tool is a plastic cylinder closed on one side with only a grease jerk in it. Open on the other with a smaller sleeve inside and with a few threads to screw it on the spindle.
Sorry for the bad explanation, not to easy for me in a foreign language.
Maybe a few pics will say more than 1000 words:
With a d cell (tool is right
http://coloradok5.com/forums/attachment.php?attachmentid=40168&stc=1&d=1171222511
The back with the grease jerk
http://coloradok5.com/forums/attachment.php?attachmentid=40169&stc=1&d=1171222511
Here you can see the front - only 3 or 4 threads are necessary to put it hand tight onto the spindle
http://coloradok5.com/forums/attachment.php?attachmentid=40170&stc=1&d=1171222511
Another shot of the inside, there's an o-ring between the threads and the inner part (hard to see).
http://coloradok5.com/forums/attachment.php?attachmentid=40171&stc=1&d=1171222511
Edit: Sorry, can't find out how to post text between pics
, so the above text referrs to the 4 pics on the end.
All you have to do now is dismount your locking hubs, attach the tool to the spindle and pump it with your grease gun. From time to time look at the inside of the knuckle. If the bearing is properly greased, the stuff will be seen around the dust shield (about 20 pumps with the gun).
I see that you did grease your spindle bearing very well, but after a little mudding this may help pressing debris and water out . . .
The other thing:
When installing your locking hubs, DO NOT use grease (although you love to play with it lol). I made that mistake for years an was wondering why my hubs failed. With the new warn premiums the installation says that the hubs were oiled from the factory and that should be enough.
If you're afraid of water harming the insides, than maybe some o-rings for the torx screws and a thicker o-ring for the cap may help.
Personally I would not use any sealant on the hubs. I open them a lot (bearings, greasing, rotor etc.) so sealing and cleaning it each time would be a pain.
Again keep on the good job Manny!!
About when will you doing your first mud pit with the D60/14b?
Walter
