thierryben
Hi guys , I need your advice , because in france nobody knows the K5 full size ,
on my Blazer K5 of 1990 I have in front and rear 2 axles in gm 10 bolt 8.5" with 30 spline ,
what is your opinion ? what is the maximum size of tires that I can use without risk of breaking my axles or diff in exterm offroading use,
I preapare this chevy for doing offroad in france and I think to put a detroit locker in the rear axle and a detroit true trac in front ,
and an other question ( the last
) it's for the references for order my locker and true trac , do you think that the rear and the front differential are the same on my axles ?
many thanks by advance from france
thierry
) it's for the references for order my locker and true trac , do you think that the rear and the front differential are the same on my axles ? many thanks by advance from france
thierry
