MaxPF
Oh, you can bet i have hidden motives for calling Cummins on a poll you postedI'll start my own thread here pretty quick, and we can compare notes (read I'll steal your ideas
) Looking forward to it!!
Did you ever read that thread with the Cummins/Burb conversion by a guy from Norway or wherever it was? Crazy detail . . . . .
I doubt you will steal my drivetrain ideas, unless you plan on running a 4 speed
I'm running an SM465 behind the Cummins. What is interesting is how I am mating it to the Cummins, and how it will live behind 800lb-ft of torque without breaking the input shaft (the guts are easily as strong as an NV4500 - probably stronger, so no worries there), and the custom 13" clutch I had South Bend build for me
. Then there's the diff gearing so I am only turning 1900RPM on the highway
OK, I will let a bit of detail out of the bag. Everyone here knows that the SM465 has a 1-1/8" 10 spline input shaft, right? Well, a Cummins will twist that right off. So, I'm replacing it with something a bit more substantial...
