Measuring rear leaf spring bushings Help!
brans87
- In Memoriam -
North Carolina
Since ORD is down for right now with there website can someone tell me correct way to measure the rear leaf spring bushings? I have it apart where can measure but need to put factory shackle back on today since truck is 1/2 way in garage. HELP please!!!!!!
from all measuring etc I did appears to be 1.5 inch hopefully ORD will open back up and can order them.
There will be two different kit numbers. They go by the shackle bushing size. The springs are 1.5" unless you get to the 56" springs for 3/4 and 1 tons then they're bigger.
The shackle bushing sizes that ORD commonly sells are 1 3/8" and 1 1/2".
A few of the later year K5's have the larger metric bushing size in the spring. Works out to be 1.70". I had Kert machine up some bushings that were a light press fit in the spring so I could run the much more standard 1.5" bushing.
IIRC ORD does list the larger metric bushing on their site.
On an 87 Blazer it's very likely to have 1-1/2" bushings. The last few years of the solid axle trucks, they did go to metric bushings that are ~1.7" but I haven't seen one earlier than 87. But you never know, and people swap things around all the time.
On an 87 Blazer the shackle bushings are 1-3/8" for sure (never went metric there).
Not sure what's going on with our site but we should have it fixed Monday.
Thanks Chris for a response. We talked a while back and you told me to take shackle off and measure so with wife and baby girl at her moms in MN I did what you told me to :D.
Yep, the 64" rear springs use the 1.7" bushings which puts them more towards the metric sizes. Even the ORD site shows that for the springs, too. I need to order those for my 64's soon.
