goldwing2000 said:I'll help. Just bring it on over.![]()
*makes a second snow ball and puts in freezer for goldwing....
Norton; one of these days! One of these days Norton POW straight to the moon!
was it metro scuba then?i got both of my 72s from Tom that used to own it.for free.goofy1 said:I got mine at the dive shop that closed up on van born and the valve was changed by them to more of a gas cylinder type valve so I could use a special fitting they sold me and pipe thread to hook up a high pressure regulator. No I am not certified but a friend at work is and told me about the used cylinders around $100. I have only had it refilled once and it was done there but they didn't ask for my certification. SEE YA ON THE TRAIL
-Tim
i also have an 80 aluminum and a 96 steel tank.Kane says we can weld something on if need be. i have old regs that might need to be converted.
not a chance Lawrence. ask Mike,he likes working in the cold.Metrodps said:It is snowing again!
Anyone want to lay on ground and help do my starter?
Maybe it was Metro but I don't remember. My tank is an 80 alum. The 96 you mention is a high pressure(5000)? Are you still planning to have them filled or just use as a reciever for an onboard compressor? I am sure any mod would void cert. If you need welding I am also available with a DC stick in my heated garageboggerless said:was it metro scuba then?i got both of my 72s from Tom that used to own it.for free.i also have an 80 aluminum and a 96 steel tank.Kane says we can weld something on if need be. i have old regs that might need to be converted.
with a 8'
door. SEE YA ON THE TRAILTHat would be nice but 'MIDNIGHT BLUE' still sits without a heart (transfer case). but the transplant is here and waiting on the adapter that is on its way. I am going to sterling inn this weekend to play in the indoor water-park anyhow. For the kidsgoldwing2000 said:
SEE YA ON THE TRAILwhen do you want to go Kane???hopefully when its warm.or warmer.goldwing2000 said:
my hub is the thing keeping the fer ba fer from working.
bastage.have fun Tim.goofy1 said:THat would be nice but 'MIDNIGHT BLUE' still sits without a heart (transfer case). but the transplant is here and waiting on the adapter that is on its way. I am going to sterling inn this weekend to play in the indoor water-park anyhow. For the kidsSEE YA ON THE TRAIL
boggerless said:when do you want to go Kane???hopefully when its warm.or warmer.my hub is the thing keeping the fer ba fer from working.
bastage.
sure Kane.goldwing2000 said:Swap ya fer an axle or two...![]()
the two 72 steels i have get questioned when i get them inspected. ones from 63 and the other from 71.goofy1 said:Maybe it was Metro but I don't remember. My tank is an 80 alum. The 96 you mention is a high pressure(5000)? Are you still planning to have them filled or just use as a reciever for an onboard compressor? I am sure any mod would void cert. If you need welding I am also available with a DC stick in my heated garagewith a 8'
-Tim
air supply for the truck they be. Kane wants one.i think he still does.
that sucks.goldwing2000 said:Well... looks like I'm going to need those spare parts myself.
Blew up the left axle shaft and the steering wheel is now upside-down.![]()
call me Kane.
boggerless said:that sucks.call me Kane.
AJMBLAZER said:I guess today's weather is making up for that stuff we didn't get the week before last.
Just drove Big Ugly 14 miles each way in 4hi the whole way to go to the parts store. Had morons in minivans riding my ass the entire time...
you shoulda "stopped for that chipmonk".and learned em.
yella or blue??goldwing2000 said:It's cool, man. I get to do something new to the truck! Never tore a steering box apart before.
The axle shaft shouldn't take more than an hour or so, since I have a spare shaft assembly.
And yes, I would very much like one of those tanks.![]()
