Latest Updates......MORE PARTS!!!
OK All,
Thanks for being patient. These things take a while, but I finally got to the point in the build process where "you pay your money and you take your chances"!!!
I ordered to complete rotating assembly yesterday for this 496 build.
I'll tell you what I know, and Scott can fill in the details.
The parts vendor was Powerhouse (shop.enginekits.com)
I decided to go with forged components instead of cast....I know this was supposed to be a "budget" build, but everything I've read and everyone I've spoken to says that the forged components are a lot stronger and worth the extra "piece of mind"....so I made the stretch with the $$$.
Parts Ordered:
4340 Forged Crank w/ chamfered bearings
4340 H-Beam Rods
New Balancer
SFI-Approved Flexplate upgrade (yes, this means some sort of slushbox gets used)
.060" Flat Top Forged Pistons w/ Two Valve reliefs 8.4:1 @ 118cc
Pre-Gapped Rings
Complete Balance of Rotating Assembly
A couple of interesting points about the parts.....the guy I spoke with at Powerhouse mentioned that the H-beam rods (although stronger than the standard I-beams) would actually require LESS clearancing to work....a good thing! The flat top pistons that were selected seem like a poor, low-compression choice (vs. a domed one) but since my final head volume is going to be 115cc, the compression will actually bump up to the 9:1 mark, which is just about perfect for this iron-headed buildup.
Total price for all components (including shipping) came to $1839.00.... not too bad considering that I elected to make some substantial "upgrades" to forged components.
Parts delivery will take about 7 - 10 days since everything needs to be balanced before shipping out, but that will give Scott time to get the heads pressure tested and get the block cleaned and prepped for it's machining (bore, deck & square)
OK All,
I ordered to complete rotating assembly yesterday for this 496 build.I'll tell you what I know, and Scott can fill in the details.
Parts Ordered:
4340 H-Beam Rods
New Balancer
Pre-Gapped Rings
That's a HELL of a piston rod!
. My last one came out of the box bent .004 and needing to be polished. When my crank guy got done with it and fitting the rods I need to run .001 undersize bearings....deep sigh
