MNorby's Goat - Ibex build
@metalguy helped me build the new hood. It has more visibility through the side of the chassis and only weighs 7lbs vs 35 on the old hood. Had to be about an inch higher than the chassis tubes as the engines sticks up through.
Yeah but the other panels had cool vinyl graphics.... :whistle:
I can show you one idea I have but I would need a good side picture.
The rig worked good in moab. Initially had the ride height a little low and was hitting belly hard a lot but adjusted that easy enough one evening.
pretty badass stuff Matt, the Ibex works as great as anything out there...oh and happy late birthday brother!
Thank you!
I have a few updates I am working on right now, will share here shortly. Going to have to start moving my photos to a different host since PhotoBucket is killing 3rd party hosting.
How's the trans cooler working? Enough air flow? I'm planning on placing mine in a similar location.
What's the specs on the set up you have?
So far working good. Fan turns on at 180 and so far haven't seen warmer than that. It is the larger B&M HiTek cooler with the fan and built in temp switch.
I wish they made one of those switches that kicked on at like 170.
Yeah I don't think push in will work on a stacked plate cooler.
