More starting issues (now with code).
AlaskanDad
Registered Member
Alaska
Fires right up, but have to stay on throttle to keep running. Usually about 2-minutes, then it will hold idle without stalling. Runs rough with backfiring during this time.
Code 45
350 w/tbi and 700r4
Has new fuel pump, fuel filter, coil, thermostat sensor.
Code 45 might be an O2 sensor issue:
http://repairpal.com/gm-obd-code-45
That may or may not actually be the issue, but an O2 sensor is like under $20 last time I got one. Might be a place to start, but usually that's not used until it's warmed up a bit.
If I had more time I'd look into it more, but unfortunately I've got a packed day.
Good luck,
Clay
