Motor mount replacement
Mine does not have that curved metal but the sleeve is needed
Keep it and when you do your swap put poly back in will last longer
Also the smaller metal prices reuse those on the rubber
Im Going to use the rubber top and keep the poly bottom since I can't find replacement hardware for that. The sleeve you refer to i have to reuse from the poly as well....if I can and if not I'll just have to leave the poly mounts on the transmission
Once I install the ORD motor mounts I'll put the poly back on the transmission mount.
Thanks for replying, possibly I'm asking too many questions... I'll keep quiet if I can for a few days or so..
Thanks again
na man was just busy today sorry for the delay answer
there has to be a sleeve on the bolt that goes through the trans
i will look for the hardware i found a source but cant remember where
Yeah the energy suspension has it.. so I'll use that if I can
thats them, but there was a place i had found for bolts sleeves and all stock stuff
just have to find them
How far up can I jack the the Tcase without damaging anything? I had it up but was afraid to go too high. So I couldn't get the ploy mount out... so I just put the bolt back through.
There is that piece that goes into the crossmember where the sleeve goes through.
no won't hurt the trans. I am not familiar with the twin stick linkage enough to know if it will limit or get pinched in between the trans and the floor board.
You shouldn't need to raise the the t case tarns much to change those mounts.
Raise it up a 1/4" and slide the mounts to the out side to move and then slide new ones in
