are you coming back through or is this it?
That sounds awful lot like my kind of trips, just patch an keep going.So synopsis of our drive,
1606 miles of wiggles and wobbles.
The 454 in the suburban sat over 10 years in a motorhome, parked in the yard of a member.
It got thrashed together and driven 150 miles before we left, each night i had a list of things to fix and adjust.
It now rides on a set of used 38 14.5 mtr's
Leaving our last home town i broke a serpentine belt. 15 minutes in, swapped it out getting gas after waking to autozone.
West of Monroe La, day 1, the bolt in my exhaust hanger rattled out, muffler fell and broke the weld at the y, directly under my floor board. It was removed from under the truck.
All of day 1 I fought engine temps, and am ashamed to say I ran that joker hot all day.
Day 2 i started the morning by removing the air conditioning condensor and 8 inch lights from the bumper.
Then we went thru Texas, that was a truly miserable day, it started with expansion joints in La. My truck has a light rear suspension with way to light of a shock for the top heavy suburban. So it has a good amount of body roll unloaded, and when loaded to the roof, it gets worse. We discovered that when the truck hits an expansion joint and isn't square to it that it starts to wiggle side to side, and then it makes the trailer start to sway quite violently. Let's just say people gave us a wide berth. As a side note, I will continue to say Dallas is the city I most dislike driving thru. I now have more gray hairs thanks to the construction zones and constant wiggles.
My left side now has a darker tan than the right thanks to Texas.
Day 3, we left Dalhart Tx. About 4000ft in elavation, with less humidity and a rich tune, we had good temps in regards to my coolant, but the floor boots board continued to burn my heel. We got a ways into New Mexico when the return line from my power steering rotated into the pulley and decided to no longer hold fluid. I cut the line and bypassed the cooler and on we went.
In Raton NM we topped up the power steering pump, added a qt of oil, leaned the carb as much as i could and went over the Ratom pass into Colorado, it chugged along over 7k feet and back to 5k.
Day 3 we started with the wobbles, with my steering fluid now hot it started to be susceptible to the death wobble. First it was raton pass, at the summit they were doing construction, and the front passenger tire dropped into a drain and that started the wobble.
The wiggles and wobbles continued thru Colorado, especially in Denver with the construction and slow downs. Around Denver the seal on my output shaft decided it didn't like hot fluid and started to leak. I topped it up periodically.
Finally arround 11pm we rolled into our hotel in casper.
I'm very happy and thankful we made it, my wife was very patient and drive behind me the entire way so someone else wouldnt follow to close lol.
