That 2nd picture looks like an ad for Yukon Gear.
Any updates? Picked up a rusted up 83 to build, just read back through for more inspiration.
Great time wheeling, and it was good to catch up. The ‘yota is a damn fine trail machine, and with a very capable pilot - wish you and Christy could have joined the Shenanigans at Hoffbrau.I got a chance to wheel with @AgDieseler a month or so ago when he was in town for SEMA
I follow your logic - if there is zero deflection of the spring around the open hole, including some small amount past it, you might be in business. Weight is also on your side.Seems to me that as long as the empty hole is within the length of the perch and spring plate, pinched by the U-bolts, it shouldn’t be an issue.
I'd leave it. As Keith says it will keep the leaf pack from moving around too much. Important when you constantly go from full bump to full rebound. Too far apart to just drill a new hole is your current perch?
