Small update. First off, Biggest of thanks to eaglemark! For his patience, understanding, and helpfulness! He is the go to guy for your fuel injection needs! For those of you that have been following along, you will remember that it turned out when i got this motor, the harness and computer i got with it were 2000 camaro pieces. The fella i got the setup from told me that it was wired and programmed for a 5.3. That turned out to be incorrect. The computer as it turned out was actually programmed for an LS1. Surprisingly, it actually ran the the 5.3 fairly well. But not quite right as you might guess.
At the time i found this out, i was basically out of funds to get the computer reprogrammed. Thats when eaglemark stepped up and graciously offered to reprogam the computer to 5.3 settings free of charge! It turned out be fairly tricky as we found out due to the ls1 wiring. In the end he worked his magic and got me properly programmed computer.
Still, i had a problem with the the new program not reading the oxygen sensors. I knew that it was something to do with the 5.3 program not playing nice with the LS1 wiring. I even tried to get eaglemark to swap the ls1 portion of the program that read the oxygen sensors. He explained to me that not only would it be massively complicated, it wasn't needed. A rewire of the oxygen sensors would be all that was needed.
I wasnt looking forward to ripping apart the harness to re wire the sensros. But I did a ton of research and found that the solution was rediculously simple. Most of my research was done on lt1swap.com which is an invaluable resourse for swappers. In it he not only explains how and why the o2 sensor wiring needs modified, but explains the differences in the oxygen sensors themselves, as well as provides wiring diagrams for them on various LS vehicles. After reading the info over and over, it all became clear when i compared the LS1 o2 sensor wiring to a 5.3 o2 sensor wiring diagram. Everything is exactly the same between the two. Except, the 5.3 wiring has pin 63 tied into the tan wires for the oxygen sensors which provides a ground path. After i added a pin in the 63 position and spliced it into my tan wires, I had the oxygen sensors reading perfectly again!
Here is the LS1 (and case ground early truck motors) o2 sensor wiring, no pin 63.
And here is the 5.3 wiring (later isolated ground type), Notice pin 63 tied into the tan low reference wires.
