TheBeast_88K5
Banned
put a booster pack right to the starter.. we do that sh*t all the time.... GM ran 4 g on ton's of stuff...
4gau is the "minimum" you can get away with....
Saves the car manufacturer $5/car, times 100k cars; at the expense of longevity.
Obviously, you guys get that, I just thought it relevant.
I was reading fun stuff about that fact.
Like, GM's 70's "Hot Start" issue being cause by resistance build up in the (too thin) wire.
Or, Super Duty's eating up Starters, due to voltage drop.
In th Super Duty's case, the wire corrodes 12" from the Starter... (Too thin, corrosion takes over.)
That said, the Mofo' should be working.
Im thinking its a grounding issue, too.
Gonna go over all of mine, and maybe add a couple...
Where would I put a ground, on the starter?
Just run a ground strap off one of those bolts?
