LIVEAnimals
I was going to say the same thing... you gotta clock them all the same way!You will drive us nuts if they aren't!!!
Agreed
People that dont line up valve cover t-handle bolts drive me nuts as well. That and spark plug wires not being in line and all that. My OCD goes into ludicrous speed.
Now that you mention it, the heads matching the Water Pump, would make the look.I think a silver or gray would suit the heads better.
But yes the valve covers look much better than the wood imo
I was totally fine with it, till Skinny Jeans opened his trap.Looks good to me![]()
Some jerk, not me, snapped half a header bolt off, in the head.
Now,I have to extract it, or something.
They were also kind enough to strip the threads of another bolt bore.
Thanks, previous owner of these heads!
carbide drill, punch the center of the broken bolt, start with a small pilot hole and work up til you just have the threads remaining of the bolt and use needle nose pliers to get it out, had the same problem on an old truck of mine.
