Its not the box... The box works just fine.
How do you know that if it won't run right?
Nope.... I put a 12v switched source to the BAT connector.
Now, it runs even less!!!!.
Correct me if I'm wrong but with an msd box you aren't supposed to hook up the Bat+ terminal on the distributor. All power to the coil goes through the box on the B+ and C- terminals.
this was part of a wiring harness change right?
You might want to try this, it could be your miss. Never knowI'd bypass the MSD completely at this point.
It's just another variable to diagnose on a truck with too many unsorted issues....
Once things are running and stable, hook the MSD back into the mix.
Just my $.02
-G
