That's a cool place. We were there in 2009 for one of the XRRA races. I'm going to have to look through this thread! Stuffing 44s is impressive!
Dude, I haven't been on the site in quite some time and wow. You've made A LOT of progress and bravo. Looking really good!
love this truck nice work
I assume you still need to run the figure 8 adapter between the 205 and the Titan?
Nice. Did you pick up a couple of the adjustable detent doohickies? I used them in my landcruiser build and they made shifting SO much easier.
https://jb-custom-fabrication.mysho...roducts/adjustable-shift-detent-kit-for-np205
Nope, the titan box is built that you can run either a 6 bolt round OR a fig 8 case. The way Kris explained it to me was if you have a 6 bolt round pattern, than you just don't use the 3 bolts on the bottom. He decided it wasn't worth designing two cases and just designed one that will work with both. So if you look on his website at this thing (here: http://www.northwestfab.com/BlackBox-i-NP205-Titan-Series_p_2402.html) it shows how its intergraded...keeping the length so short compared to everyone else, and making it the most compact out there...which is what I cared about
Ah ok. Make sure you mock it up with the JB fab hardware on the rails, for whatever reason they made their adapter clearance around the shift rail pretty tight so I had to open it up.
The doubler will be a nice addition.
Martin
How did it feel at first, cutting into pretty new tires?
I looked back to see what length shock you went with but seemed to have missed it... Do you mind sharing the length?
