K5dreamer
so im looking at upgrading my rear lighting because i really cant see anything when im in reverse (yes the backup lights are still good). Ive got a set of fog lights that i took off the front bumper (PO installed, aftermarket), they are pretty small (not KC, more like, import tuner grill install fog lights) so i can probably tuck them up under the bumper pretty easy, but i dunno if they still work, i think the PO hooked them up to the blackout light circuit, which if memory serves is 24v??? I also have a spare headlight that i replaced because the low beam went out, but the high beam is still good, so i was wondering if any of yall had installed a headlight on the back end of a K5 somewhere that came on with the backup lights. and if so, where/how did you wind up installing it?
