as a ex tire guy i would do 2 and 2 if you have to do this . and mark them so you can keep them on the same axle . ex: 2 front or 2 rear .
Happened on my freightliner.Waiting for crossover steering, PVC inserts, driveline flanges and other little stuff to come in this week so I can take it on a test run and hopefully go camping this next weekend....... got my kids to help me get the Brakes and hydro clutch bled, replaced the motor mounts, pretty trashed.....went to try to fire up the motor after little over 13 months of sitting, no crank....checked column wires I replaced, and fuses, no power to starter. Then thought, maybe the new motor mounts could be the reason,....hooked up a temp ground wire from battery to frame and truck fired up!! Lol. The old motor mounts were so bad, they were actually making a good ground from frame to motor. Apparently they have been like that since I swapped the motor about 16 years ago cuz I’ve never had an issue starting it. Haha! Being a teenager and having my friends helping me......... They should have been replaced then.
Will do!! I guess I need to see what’s up with the temp sensor first.solder the wire in and be done . i use to fix computer boards with a paper clip and some 60/40 rosin core solder all the time on a burnt or snapped run .
