CDA 455
3/4 ton status
it is cast into the dif
Drum brakes? Look again. Its got the "C's" which means open knuckles and will use disc brakes.What are you going to do about the drum brakes?
'Nuff said!When you say 'hi-9', are you referring to a high pinion 9 inch?
Because if you are, I was told by Currie Enterprises that the high pinion 9 " is much weaker than the standard 9 ".
Also; a 10.5 " ring and pinion over a 9.75" or a 9" ring and pinion.
The power supply will be a Ram Jet 502 connected to a beefed up TH475.
High pinions only give you a way better angle. I dont think one is stronger than the other.I always heard that a high-pinion was stronger in a front axle, and a low-pinion was stronger in a rear axle.
)Currie Enterprise told me they took an existing product (A 9" third member) and modified it to work as a high pinion, compromising strength for drive line angle.
Playing devil's advocate:
So why isn't hi-9 being produced by every major axle builder in the 4X4 world?
Why is the Dana 60 still a sought-after front axle?
I've known of the hi-9 for about 15+ years. That seems plenty of time for the craze to spread, don't you think?
Seriously; what is stopping you?
