Well, been a while since I have done much to this but I need to get it on the road so I can take my dd off to do some bigger repairs to that.
I got the fender/inner fender off and gotta get new ones this week to throw on. Gotta do a little rust work to the other fender and spray the cab so its all one color. Then there is a bunch of little stuff to do. I really wanted to do a lot more before it went on the road but time is running short, and I need to fix my other truck for next winter.
Went over today and decided that the other fender has to go as well. Want planning on it but it did have a hole in it and I might as well do it now. The inner fender is ok on this side. I do have a bit of rust around the cab support and the bottom corner where the fender mounts. Not that bad thoughl.
Got the fenders finally on today. I think they fit very well for aftermarket. Only issue is the hood alignment, very tight on one side not so on the other, but its an even gap front to back. I will tweak the hood to make it look better. The body lines line up well and and the door gaps are good.
