My "Official" Stepside Restoration Thread and LS Swap 2021
it would be nice to see how the brace turns out, I'm thinking about putting one in mine as a preventative measure. Nice truck, and I'm very envious of your SM465.
Thanks! The SM465 is one badass trans :D :bow:
Tomorrow I will call my neighbor to see if he will help me out welding the brace in. :weld:
Just a new picture I wanted to throw up because I am a picture whore
Did a little wheelin'
Enjoy some pictures:
And finally enjoy the video: ;)
Update with tsome pictures
I did a little wheelin for the first time since the last pictures I put up. I took it easy, but trying to get a poser shot I ended up digging in with my rear bumper. Luckily I didn't get stuck. :D Enjoy:
I'm pretty excited, I have some new plans for the truck and a few other things cooking too. I forgot my camera this weekend so you'll have to stay in the dark till next week... :D
Just read the whole thread. Pretty impressed with the time put into the truck. Looks great, I love the look of the old step-sides. I blew my 10 bolt sat. night, probably out of it till spring. How far from Hingam(?) are you? I lived there and in Brewster for a few years. Would love to go back out there and wheel some time. Your pics make me miss wheeling my own mud. Truck looks great, sounds pretty good too. I'm concidering turn downs at the mufflers also. What do you think of them? Wow, a lot of run on babbling, huh?:doah:
how'd that hub work out 4 u?
Tom
Hub works perfect... only I might have screwedup installing the auto locking mechanism because it just clicks when i put it in 4x4... :mad: I'm taking it apart again this weekend to find out if anything is screwed up.
Thanks, I appreciate it. I am probably like and hour drive away from Hingham. I'm in Franklin btw. Unfortunately my local spot has just been shut down by the propperty owners... :rolleyes: But I am still wheelin down on the Cape while I'm in school. Turn downs were alright. I modified my tailpipes so now i put them back in since. Turn downs are cheap and to me feel like you just didn't want to finish bending up the exhaust, but to each his own.
if you need the lockin hubs let me know, like i said i only am missing the selector, but ill look for it
Updates!!
So i have been busy gathering parts...
I had a small hickup with the hub... but all is well. I will do the driverside soon. My aluminum wheels are much thicker than the stock steelies so only about a 1/4" of threads could be used with the stock wheelstuds. So when I went to rotate the tires I stripped 3 studs on the passenger side. And that is way too many to drive safely on. So I researched high and low for longer wheel studs. My solution was Moroso studs pn: 46220. These require a slight amount of clearancing in order to drive them into the hub all the way. My hub problems came from being drunk while working on the hub and dropping it, denting the front flange of it and bursting the air hose that it landed on... :doah::crazy: Anyways, I got a new one and threw all back together with new studs, bearings and seals. Now my hub likes to click when I engage 4x4... :mad:
I had to get new lug nuts with the larger 1/2"x3" studs. But wow are they fancy. I don't think I could ever strip those. :D
Ok now for my future projects:
Cowel Induction Hood
New stepside fenders
Rear bumper
Paint interior
New seat foam or buckets... who knows...
Headers/exhaust
New wiring harness
Finish autometer gauges
:eek1: And thats just what i can think of on the top of my head!
Ok so some of the parts I have gathered:
Autometer gauges, wiring harness, and all wiring connections, extra wire, heat shrink wrap, and those black loom thingies.
The wiring harness I got based off of a recomendation by another member on CK5. I couldn't afford to do a painless harness for $560+ just because it says painless on it. So I went with Ez Wiring's universal 21 circuit harness that is perfect for our gen of trucks whether you have a bare bones pickup or a fully loaded burb. So 1 ebay bid and $180 later I have in my hand a kick ass wiring harness. While I do the wiring, I am going to do the headlight upgrade, autometer gauges, and propperly rewire my offroad light, and most of all wire the stereo so it doesn't keep cuting in and out over every bump.
Pics :D
The fuse box look nearly identical to the corroded and spliced factory one i have
My favorite part about the harness is that every wire is labeled every foot or so :waytogo: :bow:
This is also from Ez Wiring. Its their aftermarket gauge mounting solution so you can retain the stock bezel and have the autometers recessed into the dash much like how I did the 2 gauges I put in on the top two slots.
Man, with my time and labor, I don't think I can do my aluminum bezel for that cheap. You may have just given me yet another thing to buy. Thanks for the info.
So that bezel allows you to run 3 3/8ths speedo tach, and what size of the smaller gauges?
ya 3 3/8 speedo and tach with 2 1/16 smaller 4 gauge set.
uh oh am I giving Ben ideas for his build?
