I took the truck out today to take advantage of the nicer weather before the cold set back in. So I took the obligatory poser shot:
After a conversation with Deuling earlier this month, I disconnected the sway bar to see how my truck would ride. You see I was looking at the photos from the Dune Party trip earlier this summer, particularly the flex shots on the RTI ramp. I noticed that I really should have flexed better than I did. I know I had some limiting factors at the time like short front shocks, fender clearance, and track bar hitting the frame, but most of all, I think it was the sway bar.
I have always been a believer in the sway bar because the truck sees plenty of highway time, but I have never actually disconnected it and tried it. The verdict: definitely a better ride. It was less jarring and it felt like the front end actually moved like it was supposed to. Go figure
Now there was more sway but it was manageable. I do need to replace the frame bushings for the sway bar and then I was thinking of using the ORD quick disconnects for highway use. Opinions? Is it worth my while?
