Update!
Not much progress over the weekend, but today was all for the truck.
I made a patch panel and welded it in. Althought the welds suck, I am terrible at welding sheet metal. Give me 1/4" plate and I can go all day. But seeing as how there was still insullation behind the firewall and the fact that the surrounding metal got hot enough to make the old rubberized undercoating go up in flames. So I tried doing a tack here and a tack there going back and forth to keep the heat down. So I was a left with messy bogger welds and with the inner fender in place its too tight to fit my grinder in there and I dont want to drop the inner fender when I will have to drop the gas tank to get the old wiring thats clipped to the frame behind it.
So this is what I'm left with for now:
Rustolium Flat Black because I ran out of my fancy Eastwood stuff
So the fuse box is now mounted up and it looks pretty awsome. I am very pleased with this kit installation so far has been very easy and straight foward.
Now that I have made all the connections somehow I have to snake it up over the column back into place.
Also I picked up some hole saws for my gauge mounting and so I had to try them out:
What do you guys think of the gauge mounting? For the small gauges I am going to do exactly what I done before and mount them to the bezel and not the green plastic thingy.
What I still need to figure out is what I am going to do for my idiot lights that I still want to keep like my highbeam light, brake light, and bat/alternator light. The directionals are still in place so they are all set.
