SLO C5
I went out to the dunes today (for my first time) with a fellow CK5er(bucksntrucks969), and was having a great time playing around. I got stuck on a slight hill, and in the process of trying to get unstuck I blew up something in the front axle. It made a pretty nasty noise, but now the front wheels don't do anything. I have no FWD when in 4hi, or 4lo, and the front DS is spinning. As I was trying to climb out, Rick said that the front left tire would rotate a little bit on occasion, but still pretty seldomly. It's an open D44, so if just 1 of the shafts or hubs blew up then I'd have no FWD at all, correct? I'm pretty far out there, and happened to be in a spot where 2WD would not get me anywhere. We drove around looking for anything flat that I could limp through and there was nothing. The CK5er with me has a diesel K5, and he doesn't think it has the power to get tow me along while I follow in 2WD. It couldn't be in a worse spot. I'm not sure what's broken. Everything on the outside looked OK.
So, my Sub is sitting out there overnight, and possibly for a few more days. I really don't want to try and fix what is wrong with it(I'm not even sure what it is). I'm thinking someone with a badass rig can get me outta there, then I can take it apart in my driveway. It's a good 20 miles from my house, and depending on multiple trips from a friend that can even get me out to my Sub is a major problem. Let alone actually fixing the problem and getting the right parts. Man, this sucks!
it's a greasy job tho.
