My trucks winter build at a glance...
4x4mike said:
The big IOR thing comes off. There are flange thingies that hold it on. The only reason I know is because he posted some pics when he was building it.
What he said.
Canadian Trailblazer said:
:shocked: Download this file and check it out. Quite the transformation. Do you remember what year was that taken?
LOL!
I believe that was thanksgiving 2003 at hollister...
ok so would you be interested in making somthing like that for me?
a kit mabye?
pricing?
thanks,
dale
Tell me more about your cable shifters. Not so much the cables but what your doing for the shifters.
Thanks, Todd
hey Jason your going to have to change the title of this post to winter/fall/summer build. :p:
looking very good.
id like to donate my hella 550s to project.
everything but the lights are great. :crazy:
willyswanter said:
I was thinking of changing it to the 2010 plan :D
You coming to the fest?
Im hopin to make it. Noel and I are going up to Bald on the Sun so I can see if everything is OK since the last work I did.
Yeah I really wish I could drive up and ride bald with you guys but I have to spend my only day off (sundays) on the truck to get it ready for BF. :(
Hmm, I guess I never updated this thread huh? Well I'll give a quick rundown from where I left off till now.
Since the last pics in here I managed to get the 3/16" plate on the boat sides and got that all finished up as you can kinda see in this pic:
Then a bit of wiring and that was about it and it was off for the maiden voyage of blazerfest. Got there and on the 2nd day broke a shock mount on the pass. front because it hadn't been gusseted or braced yet, just tack welded in place :doah:
Little tilted...
So after getting it back home I finished the shock mount setup and decided to get it painted before heading to the rubicon. Scuffed the truck with scotchbrite pads and sprayed the body with the OD green from Home Depot and then masked the entire body and sprayed the cage Stainless Steel also from HD. Also got the 5/16" underbody skids back in.
Then it was off to the rubicon where I found out that a tack welded in place rear 4 link crossmember wouldn't work :doah: See kids, this is why you don't try and rush to get to an event...
Anyway, got back from that trip and built an entirely new rear 4 link crossmember that won't even move and finished up a few other loose ends just in time to head to moab for Blazer Bash. That was a much more successful trip that had no breakage. Also got chromoly shafts in the front with CTM's and drive flanges. Much nicer not having to worry so much about front axle breakage.
Still need to finish the bed so that I can get my spare parts and tools out of the cab and build my spare tire carrier. I have the rear seats and harnesses just haven't put them in yet due to what I just said, the tools are taking up the room... The inner cage is still just as you saw it in the pics, unfinished. Need to get that done as well. Also working on my doubler and picked up some new tires tonight, new to me anyway.
Tomorrow and Tuesday are designated truck day so I'll be doing bump stops in front, sway bar in rear, working on the bed, new tires, etc so look for some updates after tomorrow and Tuesday :D
Okie dokie!
Both tires mounted at 20psi, jack under front axle to take truck weight off:
I think they fill out the truck a bit better since the truck is so big. In person I think it looks alot better than it did before. The tires are a good 3" wider and 2" taller (duh).
Also got my hood latch on finally. I actually found my origional one, somehow it got into the storage compartment on the side of my MIG welder.
42's for sale now!
