loren
I'm new to solid front axles and crossover steering, so go easy
. Just picked up a 72 blazer that has: Dana 60 up front (dodge I believe), crossover steering with heims all around, steering arms that appear to be intended for a high steer setup, and hydro assist (which is leaking somewhere).
Everything seems to be in working order, but I'm wondering about this setup since I haven't seen anything like it. There are arms on both knuckles which points to a high steer setup, but this is definitely not high steer as the tie rod is below the leafs, right?
Notice the 2" sleeves/spacers that drop the tie rod down. Is it safe to drive with these? I'm wondering why the PO attached the tie rod to the steering arms instead of the knuckle? Was it for additional clearance, mayebe? And why not just go full high steer if the components are there?
Drivers side:
Passenger side:
Heims:
Top view of drivers steering arm:
. Just picked up a 72 blazer that has: Dana 60 up front (dodge I believe), crossover steering with heims all around, steering arms that appear to be intended for a high steer setup, and hydro assist (which is leaking somewhere).Everything seems to be in working order, but I'm wondering about this setup since I haven't seen anything like it. There are arms on both knuckles which points to a high steer setup, but this is definitely not high steer as the tie rod is below the leafs, right?
Drivers side:
Passenger side:
Heims:
