gotblazers
Well, I installed the new cable and it didn't get any better w/ 12v. Then I tried adding a thick ground cable from the hinge mounting bolt on the bumper to the body of the truck, not better.
However, with the truck running and pushing higher amps through the wires, the window is quicker with just the cable replacement. I think I'm going to do a relay mod with new power wires to the rear just for the window motor.
When I get to it, I'll post up with results.
Well i'll share my experiences with you from this weekend getting my 1991 C2500 Suburban power rear tailgate to work. For one i dont believe you are supposed to run the ground from the bumper to the body. If i understand correctly you should be running the ground from the motor to the body for the desired results.
What i did that drastically helped. The motor has a ground strap right inside of there that goes around a bolt which is torqued down to give a solid connection for that ground. I used a ring terminal and a piece of wire to put one end of the wire onto the Original ground and then i used a self tapping screw to screw the other end with a ring terminal into the body. Drastic results but still i had the intermittent failure issue from both switches (key And Dash). Since i already had tested the motor earlier that day and realized it was good i went to the only other thing (besides 2 malfunctioning switches) that would cause intermittent failure. Their is a sensor at least inside my suburban tailgate that only completes the circuit when the tailgate hinges are in a closed position. So we cut off those 2 wires and used a wire nut to connect them creating the effect of the gate always being closed as well as always having a solid connection. The gate was closing before but they were so old they werent getting a solid connection and was causing extremely random success of the gates functioning.
Problem solved. Although, I will never get a power tailgate in my life again. I didnt really want this one but it was too good a deal to pass.
