So with the 10 rib, did you check how high the boost went?
You might not have a leak but maybe at a certain pressure the SC was so stiff the belt was slipping and not building as much anymore.
Try it before you change anything else?
So after a crazy couple weeks at work I finally got to working on my truck. New ten rib belt, didn't change boost levels but there's no dust which is good. Built a pressure tester, nothing leaked, I kinda was hoping I had some leak that would explain it all but nothing. Got around to calling a local machine shop and found out that a custom pulley would cost me around 450 dollars to get made. So I did some looking and figure that a 1.5 pulley would about as small as I could go because it'd max out the SC at 2500rpm and be in its efficiency range at 2000rpm which is perfect.
My worry is a pulley that small even though its ten rib wide, how bad is that going to slip because there isn't a whole lotta surface contact going on? I also can't decide if 450 bucks is worth it to get something that is a toss up if its actually going to work. I've also been looking into turbo set ups and for a little more than what I'd pay for that one pulley, I think I could get a decent set up. What do you guys think?
I also want to check with lysholm and see how much they want for a manifold and their SC just for fun.
There's a very good reason why it's so popular (complete dominance really) on Diesels.
