I know a lot of you guys are military ride buffs so I need to pick your brains. I imagine the parts I need are going to need to be sourced from some sort of military setup out of a 6x6 type truck, or something similar.
I need two things...
1. A big transfer case, must be for a divorced application. It needs to be very heavy duty, rated for a 10ton application at the least, up to a 20-30 ton application. I could care less on what the low range ratios are, just as long as it's got high & low I'm happy.
2. A pair of axles in the same weight capacity where BOTH are steering axles, yes, I need 4 wheel steering. Planetary axles are completely fine too.
Keep this in mind if something pops into your head, I NEED to be able to get parts for this stuff locally, like bearings and seals. Even hard parts if available too. Also, where I could buy the stuff would be helpfull too.
Thanks.
Thanks.
You've got the coolest stuff sittin' around your property...
