Hang on to that picture. If you are like me and most everybody else around here, its the last time you will see that much of the floor.
I'm guessing, no fixtures. How does the tombstones stay on the bulbs? When I tried to mount my two pin ones, the tombstones could just slide off the end. In my case, down in the swamp, the rafters were not the right distance apart to mount them directly, and I didn't have any scrap lumber to attach to the rafters to mount the tombstones on. So, I went with the solder on wires.
It looks like behind the glare, that you attached some boards and mounted the lights on them.
I have not worked with the 8 footers, were they as bright as you thought?
All in all, looks good.
