Most of those bug guards attached to the bottom of the hood underneath where the exterior metal folded up and under the edge and met the inside bracing metal at the edges.
I'd almost say see if someone here wants it...lord knows I don't but it is certainly retro.
Well, if someone wanted it and I get this blazer, I'd be happy to pass it along.
Check the seat mounts for cracks, the rear tail pan for rust, climb underneath and look for missing bolts/nuts/hardware, etc. Jessie James made a pretty good "used vehicle pre purchase checklist" thread on here. Think it's stickied in the garage.
Will do!
I *THINK* I have some slider window latches around here somewhere. I was looking for rear window sliders years ago and someone sent me a little baggie of them and it turned out they were for the K5 windows and not pickups. If you need one I can try and figure out what I did with them.
cool.
'88 would be a NP208. The NP241 was new in '89, not '88.
Well, '88 was a transition year. More than likely it's a 208, but they did offer the 241 in '88.
3.73 gears and the 465 would be good for a set of 33's...just sayin'.
16's are good. I have 16x8's on mine. Means you can run all the D and E rated LT metric sized tires that are much more common now. Then again you're probably going bigger with this thing soon?
How many miles?
If I remember right, it's got 160K miles or so. I do plan on running my 38s on it at somepoint, but that's a LONG way down the road.
Usually they are bolted on with L brackets that go in under the hood and bolt to the bottom of it.
As far as other things to look at, if it has any external rust, you need to check the internals for rot. Specifically in the tail pan, and down in the corners just behind the lower seat belt mounts for the front seats.
I'll check inside, but I can totally believe that Nevada dust beats on the paint hard and could allow for a little bit of surface stuff on just the gate and door.
