Damn, I wish I had that kind of $$$
I just want one "done" by a professional. I'm getting a bit impatient and irritated. I want to drive this damn c10 and be done at least for little bit.Having just built a 383. That thing is a sweet deal. What do you think you need to add to it?
Your depriving your children of walking home because your shitbox broke down. Its a rite of passageI just want one "done" by a professional. I'm getting a bit impatient and irritated. I want to drive this damn c10 and be done at least for little bit.
I've been watching videos of "Rod knock" and im not sure if mine was just valves. I tightened the culprit down, cylinder 3 and the noise went away but. I don't know if that's enough.
I've spent enough on everything else for this truck, it's a bit lame to go with a tired questionable 350 that makes noise.
Fair point...I may go the 383 route because as I've been thinking. That would be better in my Blazer as that truck weighs far more. Then throw the 350 into the C10..maybe, that's more than I want to do, for now......I understand all that. But what do you think you would need to add to the 383? Throw your intake manifold, carb, and distributor on and send it down the road. Maybe upgrade those at a later date. I’d much rather have the bigger engine for the added torque even if it took me an hour to swap some parts over.
You dont need to break in the cam. Still need some heat cycles for the ringsThis one is in stock? The complete 383 is a bit too much$$$
Will my 650 AVS edelbrock be enough for a stroker?
Do I need to break in the engine?
@folkenheath
BluePrint Engines 383 CI Stroker Crate Engine | Small Block GM Style | Longblock | Aluminum Heads | Roller Cam
BluePrint Engines 383 c.i. small block GM style stroker crate engine - longblock. Includes 30 month / 50,000 warranty & BPE Dyno Promise. Part #: BP38313CT1blueprintengines.com
