I went down the rabbit hole on the 150mm lights. Found a couple threads via google about being able to modify stock sealed beams. As it turned out the actual light bulb came out of the reflector with surprising little effort.My search for component 150 mm bulbs was thin + expensive...
There were more options in the past.... Supplies dried up.
European spec Hella lights were expensive+ hard to find . . . . I wanted 100 or 150 watt PIAA bulbs in a Hella or Cibie crystal glass housing..
LMC....Chinese...pass
Lots of options for 4" x 6". Lights.....pondered putting four of these in my 1990 Silverado Blazer., Figured that sanding + cutting the plastic Bezels would give room for bigger lights
As I recall, research showed the reflectors in the 150 mm bulb, were a compromise compared to the larger sized lamps.
The opening was enough to mock up a H4 incandescent bulb and led version. Both were big enough either bulb touched the inside of the lens. There wasn’t any solid way to attach the bulb to the reflector either. It’s pretty much when I scrapped the whole idea for brighter 150mm bulbs and started looking for a Cheyenne core support for the 4x6 bulbs.
