New life for an old GI, 1984 Chevy M1028
My lift is currently helping build a rotisserie for my friend's beetle build so I turned my attention on rebuilding the alternator. This truck was converted to 12V who knows when but still had both alternators. I picked up these rebuild kit on Ebay last year but kept putting it off with the move.
Luckily, the friend borrowing the lift has a blast cabinet with glass beads. I was able to strip the alternator housings down to bare aluminum fairly quickly.
I broke one rear housing pressing in the bearing and had to disassemble and blast the spare alternator housings though. Upon reassembly I could not get the alternator to rotate freely. I suspected the mix- matched housing was the issue and swapped the new bearing over to the matched front housing and it worked perfectly after that.
20200613_174855.jpg 20200613_175547.jpg 20200613_175555.jpg 20200613_175631.jpg 20200613_183141.jpg 20200613_214621.jpg 20200613_214623.jpg 20200613_215430.jpg 20200614_122052.jpg 20200614_123819.jpg 20200614_143230.jpg 20200614_151914.jpg
This week I've been giving this one some love. First, I still had one front turn signal not working and found a broken ground tab inside the connector. There was also a poorly supplied turn signal wiring hack on the other side as well. So,I pulled a civilian headlight harness off the shelf and stopped it down. I unpinned the headlight and turn marker wiring and transferred it over into my original harness.
Tonight, I started troubleshooting why my turn signals failed. Fuse was good, brake lights work, no power at flasher relay.
I know the column was needing to be replaced anyway so I pulled a tilt column off the shelf in need of tightening the tilt screws and tore it down. Now 2/3 of the way back together and I need to wait to get a key made before I finish.
20200820_181929.jpg 20200820_182054.jpg 20200820_191059.jpg 20200820_191102.jpg 20200820_213900.jpg
I love that factory black crap they use to prevent corrosion. Best stuff ever. International used to use it on their battery terminals. No sure if they still do. You could get it through them and it is made by Fuch's Lubricants. FYI. Pretty sure I have several tubes at home that I acquired when I worked for International.
Hey, I don't know if you noticed, but your horse is on the lose.....
All the parts from ORD, Engineered Vintage, and a lot of used parts are ready to be installed on this. I started with ceaning out the interior and getting ready for new wiring, weather stripping and felts, sound insulation, black interior, new floor mat, tilt column, ect.
Cutting holes for the four speed while you are at it?
Martin
My other option is a 4L80E from a 1991 diesel burb but I'm leaning towards the 32 spline SM465, 241 based doubler, and 32 spline NP205 since I have most of it already in the two recent parts trucks I've brought home.
