baker440ex
Wow, this looks like a great product, but I'm wondering what they center on. Is it located precisely enough to compensate for worn centering tabs or is the only advantage greater strength? It certainly is cheaper than replacing a yoke.
i think they're designed just for greater strength. i still need to replace my yoke either way. i found that the stock style clips don't always lay flush across the u joint cap, leaving uneven tension spots if not tightened correctly, which i'm assuming will promote yoke wear. those blocks would be a good investment, especially if you're taking your drive shaft out a lot.
and that clunk from shifting from park is due to no rear brakes.
