rampage
3/4 ton status
Pipe on the end of your wrench for more leverage?I got the bottom 4 bolts ok... the dang top 2 are $%#@&!! stuck... any Ideas... shot them with PB Blast last night...
Throwout bearing slides on the collar on the transmission main shaft--so it has to go on before installing the transmission..(hope that's not bad news!)..
On most of the older GM's I've done clutches on,the fork was held on the ball stud in the bell housing by a clip--I've seen two kinds of clips,one is like a two pronged fork shape,those are used on stamped steel clutch forks,(I think its riveted to the fork)-and you slide the forked clip over the ball stud--- the older forks made of cast iron had a horse shoe looking clip that goes in the fork and you just pry or smack the fork to pop it onto the ball stud..
I cant see the image...sighYour fork looks like this one--note the clip on it..you push the fork in towards the bell housing to release it from the ball stud pivot .View attachment 251340
ah... nevermind http://www.boxwrench.net/specs/chevy_sb.htmAnybody out there know if any of these bolts going back in need locktite or anti-seize? Doing LT red on the (new) flywheel. What about the crank center bolt?
