about a year ago I had installed a fresh rebuilt 350 Flat Tappet (all I could afford and in hindsight probably should have just waited to go roller.. but I digress)
... Now, the engine builder said to run 20w-50 high zinc for 500 miles then swap to 10w-30... No problem there, pretty standard. Everyone has their break-in run in suggestions. This was his, so as not to void the year warranty I am doing what he says. Warranty has since expired but I digress.
After the engine was installed I’ve put on about 200-300 miles, that is a high estimation or dead on, I really don’t know. Odometer doesn’t work, don’t care to have it work.
Since it’s been over a year and it’s the same 20w-50 high zinc oil in there since the build. Should I do that first oil change now or wait another couple hundred miles to get that first 500 miles then change it?
It’s cooling off relatively speaking for AZ and I wonder if that heavy oil in cold weather might add unneeded stress on the engine, if that’s possible.
Thanks.
Thanks.
