Not sure if I'm posting in the right place but I don't know that it is an injection problem.
So, I swapped an ly6 and 4l70e in my k5 it seems to idle fine and run fine but when I open up the throttle to pass it just dogs and won't accelerate. I've checked my fuel pressure, it was high due to return pressure, but I was able to correct that and now have 58-60 ish psi. I recently cleaned my injectors so I don't think they are the issue. Plugs and wires are new. Transmission is new. What else would cause this issue? Also, If I back off on the gas I can get it to accelerate slowly but not enough to pass and I'm not getting any codes.
