And because your steering arm is already left of center when the wheels are straight, it makes matters somewhat worse when turning left and somewhat better when turning right.
great point.
if you fix the box and everything else is right with your setup then one of two things will help. hydro assist or a panhard bar.
the panhard bar will keep the springs from being pushed sideways but there is the slight effects it will have on flex. when flexing it WILL move the axle sideways. how much depends on how much lift you have and the angle the panhard bar is located at. a panhard bar will not effect the speed at which you can turn the wheel.
hydro will take some of the sideways force off the springs but there are slight drawbacks also. your tierod travels in an arc. a ram travels in a straight line. everybody that I wheel with that has hydro assist has a slight bend in their tierod as a result. also depending on the size of the ram you could slow down your ability to turn the wheel quickly.
with my setup I have a 2" ram with a 1.25" rod. it turns quick enough for wheeling and street driving but I can't react quick enough if I gas it in loose stuff and bring the back end around. no more powersliding.
